I remember seeing this discussed on the Mach3 support forum, it may be worth searching there for "Drag Knife", I didn't read in any detail as my only application would be vinyl stickers and I use a vinyl plotter for that.
I have v26 is there options for using a drag knife and adding corner actions??
if not, is there free software out there for doing this?
thx
- CNC Drag Knife
- Need A Quote- Drag Knife
- using a drag knife
- Need Help!- drag knife
- Newbie- drag knife
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
Not for V26, it does now exist in V31 though but that would cost a chunk of change to upgrade from V26 to V31
However you could try the software at this link to a free software that might do the job for you, it does say that it supports Drag Knife operations
https://sourceforge.net/projects/dxf2gcode/?
