Just In OT I've been a bit busy with other things. - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 35 of 35
Thread: OT I've been a bit busy with other things.
  1. #25
    No posers SBC Cycle's Avatar
    Apr 2008
    Default Re: OT I've been a bit busy with other things.
    Quote Originally Posted by The Engine Guy View Post
    James
    Does you HAAS have the programable coolant nozzles that point the coolant to the end of each tool no matter what the length, if so if memory serves right I did hear somewhere that there should be a built in delay in the control where the nozzles are set to the tools that can be toggled on/off/set, don`t know the age/level of your control so if yours is an early one it may not have that facility or I may have got it all wrong and it was a different make of machine !! (Playing the "age card" here )
    Regards
    Greetings Rob! I have the programmable coolant on a few of machines, I'll try to check that out tomorrow. It is painfully slow and you can hear the pump "dead head" when it comes on if it has been sitting for a while. There is a setting that will delay movement until the spindle comes up to speed, it makes sense there may be a coolant delay as well. Good thinking and hello!
    Mastercam X9/2018 Multiaxis for SolidWorks - Bobcad V21-V30 3ax Pro 4ax Std.
  2. #26
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by SBC Cycle View Post
    It's good to see you and thank you for the kind words old friend. I don't really use many forums at all these days other than Facebook to keep up with local friends, it seems that's the only way people communicate these days, no one makes a call anymore. To be fair, I don't do much but work these days
    I hope all is well and you are still making your beautiful reels. Your talents have always been appreciated and your personal advice and help can never be repaid. Some day we have to tip glasses
    Well, that'l warm a guy up. Thanks! Right back at you!
    Everything on hold for us right now. I have v31 and havnt been able to dig in... puts my brother on pause too.
  3. #27
    Apr 2009
    SBS TY
    if I could the first Z rapid as I program at 20,that is just the right time for coolant to be working
    Now if if I could get all the Z rapids that follow to go say 50 that is what I was after
    Without hand editing that is
    I am on V 28
    Attached Files Attached Files
  4. #28
    Feb 2013
    United Kingdom
    I've just re-worked the plumbing on my VMC and it now takes 1s to good flow and 2s to full flow after leaving it overnight!
    Bonus!
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
  5. #29
    Apr 2009
    Quote Originally Posted by magicniner View Post
    Bonus!
    never happen on a Haas,,,never
    and if the coolant does not start by the time you begin cutting .......you probably know the rest
  6. #30
    Feb 2013
    United Kingdom
    I kinda figured as much
    That pause I described hard coded into the first tool change block of your PP as I described will allow you to set the correct delay for fluid to lift prior to your first cut though.
    Regards,
    Nick
  7. #31
    Apr 2009
    It appears to have worked Nick.By that I mean the posted code looks good.
    I will find out Monday for reals.
    TY very much
  8. #32
    Apr 2009
    I should add,also along with your fix in block 2,you must also do it in block 3,which pertains to after a tool change.
  9. #33
    Feb 2013
    United Kingdom
    Quote Originally Posted by jrmach View Post
    Cool, sounds good!
    A shorter pause after the system primes at the first tool perhaps?
    ATB,
    Nick
  10. #34
    Apr 2009
    Cool, sounds good!
    ATB,
    Nick
    yeah,it is not just a prime thing after not running overnight,,just takes a couple seconds to start again after it is turned off
  11. #35
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    One way Solenoid Valve fired by the same relay/contactor that does the coolant pump maybe ???
    The line would remain full, no drain back.
    Regards
    Rob
