Bobcad Cam Turn/Mach3 to program Cnc wood lathe. On turn process, my feed rate is 35 ipm cutting parallel with materail removing .080” per roughing pass. My bit rapid feed plunges into materail to quickly. Is there a way to slow down the rapid plunge feed rate? Thank you.
