It's been a while since I used Bobart and I thought I had done it before, I know I can extrude text to a flat surface but for some reason not to a 3D surface.
Thanks Ray.
- Need Help!- Sketch a logo and text which is extrude on a cylinder surface
- extrude surface
- Need Help!- Extrude and rotate a surface
- Build Thread- Extrude curve or surface
- Extrude to multiple surface
Text on cylinder - Vectorize Text - then Project - Then Extrude
Did you extrude the text on the sphere using bobart, I see in the stock menu in bobart you can do it on a cylinder.
I can project the exploded text on to a sphere but can't figure out how to extrude it in bobart.
