Trying to bid a router job so I vectorized the art and tried to create a tool path. If I select a small portion of the vector art a tool path is created BUT if I select it all, no tool path is created. Have I exceeded some limit in BobCAD v27? Similar Threads: V Carve and Tool settingsNeed Help!- Software/ Online tool to modify G-code for unidirectional 'Zig tool path'Need Help!- 3D Roughing/Finish Tool Path Not A Smooth Edge V Carve Pro 8.5 Set height for V-carve path on a model?Need Help!- Rotory tool path is posting out new cord with every path?
Originally Posted by twoclones Have I exceeded some limit in BobCAD v27? I doubt it. It's most likely a geometry issue. Vectorizing can be tricky and make a bunch of stuff that needs to be dealt with...
Post the file. Let's see if we can help you get the job!
View Tag Cloud
Forum Rules
