airbrush
I think you have to create a new tool with manually entering parameters of the taper. I have made some tools that I had to define.
jc
unionoutfitt@yahoo.com
I want to finish planar with a taper end mill but going to the tool crib only shows endmill rough and finish as available tools....
How can I add a tapered end mill into it???
airbrush
jc
I just looked at v31 and you can create a taper tool. Not so sure with v26. I will ask Al next time there is a webinar.
Good luck
jc
No in V26 that I see
nothing in the tool that i see that allows you to set a taper...only thing that lets you set any kind of taper is in the tool and arbor if you make those
...basically a big time hack...create an arbor as the taper and poke the end of a ball mill out the end of that arbor for the tip...not so great as the simulation would then display all red i'm assuming since thats considered a collision?? no other way i can think of??
is there some other feature or something that will allow the taper mills to be picked from??
so you can create taper mills...but the issue is any of the mill 3axis routines only allow endmill rough and end mill finish tools available ..you can't select a taper mill for these routines ..basically just need a planar zigzag with a taper mill instead of a ball mill....
anyone??
guess i'll have to try setting up my hack method and see if its simulates correctly...not sure if it will since technically it will be an arbor (in place of the cutting tool to fake it...) ..so not sure if it will actually remove material in the simulation....
wood project, scrolls/filigree details...I did it in the past with a standard ball mill....but would have rather used a taper mill for it...
I could just run it with a taper mill and it will probably come out fine...but just wanted to simulate to see what issues or details change as a result of the taper....
