Need Help! Contour? Offset?
Results 1 to 3 of 3
Thread: Contour? Offset?
    May 2013
    Default Contour? Offset?
    Using BobCAD V27 to make designs for my cnc router and cannot find how to draw this border around text. The end product would be v-carved text inside the border layed over a textured background.
    The Contour tool in CorelDraw does it nicely and Vectric apparently does it with an 'offset' tool. Is there a tool in BobCAD to achieve this?
    Contour? Offset?-magacontour-1-jpg
    May 2013
    Default Re: Contour? Offset?
    Quote Originally Posted by twoclones View Post
    Utilities/Explode
    other ways also but that might work ok for you
    Attached Thumbnails Attached Thumbnails Contour? Offset?-explode-letters-jpg
    May 2013
    That did work once I found Offset under the Other menu.
    Thank you
    Contour? Offset?-captureoffset-jpg
Contour? Offset?
Contour? Offset?
