Need Help! bobcam posts point to point instead of I & J's
Results 1 to 3 of 3
Thread: bobcam posts point to point instead of I & J's
    Dec 2015
    Default bobcam posts point to point instead of I & J's
    Member Bazzer's Avatar
    Apr 2016
    United Kingdom
    Default Re: bobcam posts point to point instead of I & J's
    Yes it is an option that you have missed, it is in the posting page which comes after you choose your machining stratergy, click the box called Arc Fit and play around with Arc Fit Tolerance, you can often make a G code set about 1/4 the number of lines using arc fit.
    Regards
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V30 Mill 3 axis Pro, Bricscad V14 and MOI V3 with CNC-Step High Z 1000S and Wabeco CC-F1210
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by Bazzer View Post
    Regards
    Barrie
    There are a few other areas and things that go along with this.
    Post setup can do this. Particular toolpath strategies do this... the geometry itself!
    Arc and smooth spline geometry can post ijk values without arc fit set...
    Arc fit is more of an added method to control break/angle values in the code generated and scrunch things down even further...
