Newbie Spiral Milling
Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Spiral Milling
    Aug 2005
    Default Spiral Milling
    I have V28. I want to mill the perimeter of a part. I want to spiral down on outside instead of stepping down.
    How do I do this in V28
    Rob
    Gold Member Jim Dawson's Avatar
    Dec 2013
    Default Re: Spiral Milling
    I don't use BobCad but I think I can give you a generic answer. I am assuming BobCad has spiral (angle?) lead in capability. Set your DOC to full depth, and set a shallow lead in angle. Then look at the tool path, adjust the angle as needed to get the approximate stepdown per pass that you want.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2012
    Quote Originally Posted by artracing View Post
    Rob
    HI there..I have BC/ V29 no outside spiral only Contour Ramping...
    Inside Pocket has spiraling.....
    Aug 2005
    That might be a creative way to do it.
    I’ll try
    Thanks Jim
    Rob
    May 2013
    Rob
    2 Axis -- Pattern -- Contour Ramping
    Attached Thumbnails Attached Thumbnails Spiral Milling-contour-ramping-jpg
    Aug 2005
    Yes. You are right. I noticed the profile finish doesn’t have contour ramping. Wonder why.
  7. #7
    Gold Member
    Apr 2009
    Probably because in a finish pass it is usually best to go full depth so you don't have tooling marks.
    Tool Pressure comes to mind (spring)
    Keeping the tool at one constant level,,,your cut might even be a few tenths of a thousand tapered,but it will be consistent.
    A few tenths at a contour tool path will show
  8. #8
    Aug 2005
    Very true but there is a problem side milling 2.6 tall piece in one shot. Unless you have a 3” tall carbide mill that’s in the $300 range. Jim Sawson here showed you can use cheaper mill and spiral down. I did this finish cut with 4 flute and it was almost mirror finish
  9. #9
    May 2013
    In the next window after contour ramping in parameter setting the -- depth per pass / depth of cut makes in easy
  10. #10
    Aug 2005
    Quote Originally Posted by RAF. View Post
    Yes, very likely use it all the time now.
    Need to use it on 2” hole for better precise cut. Haven’t tried that yet.
  11. #11
    Gold Member
    Apr 2009
    You can just use 2 roughing contour tool paths
    2nd one with zero left for finish
  12. #12
    Aug 2005
    picked up V31
    Got mislead in contour milling. Plunge rate is new feed rate.
    no matter what you put in for feed rate it only follow the plung rate.
Spiral Milling
Spiral Milling
