Newbie Spiral Milling - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Spiral Milling
  1. #13
    Gold Member
    Apr 2009
    Default Re: Spiral Milling
    Quote Originally Posted by artracing View Post
    I have V28. I want to mill the perimeter of a part. I want to spiral down on outside instead of stepping down.
    How do I do this in V28
    Rob
    you could always use 3 axis wire frame
    albeit more time consuming,you would have to draw your tool path and draw leads and compensate for tool size
  2. #14
    May 2008
    artracing
    this is contour ramping in 2 axis
    just enter the same feed rate for x y and z
    set feed plane just above the part something like .010-.020-.030 default is .100
    do not use a leadin
    use depth per pass and set it shallow to start (not knowing what cutter or material) cutter is critical musst plunge well
    finish pass would always be a sraight line cut
    if you want to use ramping for finish pass, just use side allowance for rgh and "0" for finish pass
    this is very useful toolpath
Spiral Milling
Spiral Milling
