Problem Drawing a spline
Results 1 to 7 of 7
Thread: Drawing a spline
    Feb 2009
    Default Drawing a spline
    Ver 29, wind 7, standard mouse
    when I try to draw a spline it acts like it is on some kind of snap to grid.
    I can't get my points put where I want them, when I click the spot I want, it jumps to the left or right.
    what am i missing?
    Attached Thumbnails Attached Thumbnails Drawing a spline-screenshot-2018-10-15-11-30-56-a   Drawing a spline-screenshot-2018-10-15-11-30-50-a
    David L. Aery
    www.hooksolutions.com
    Apr 2009
    Default Re: Drawing a spline
    The "help" menu should help explain all the different kind of spline drawing tools
    Feb 2009
    thanks for your suggestion but I know how to use the different splines, the spline doesn't work as expected. I have brought a pic in BobArt and done a vectorization on the pic, it is just letters and some of the lines need to be "fixed" to make the lines look smoother. so when I try to use the spline, it does not put the control points where I click, it moved to the right or left of my "click". Now if I try to use the spline somewhere else in the drawing away from my vectorization the spline works as expected.
    Here is the file.
    Attached Files Attached Files
    David L. Aery
    Feb 2009
    ok, I read the help and it was helpful. didn't know there was a "Snap Increment Values" I changed it to 0.001 and now it works! I just thought I knew how to use the spline
    Thanks!
    David L. Aery
    Apr 2009
    you can also zoom in on you pict and sketch/point and when all points are in place use the spline tool
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by jrmach View Post
    Should be a little icon in the lower right corner that toggles it on and off too.
  7. #7
    Feb 2009
    Quote Originally Posted by BurrMan View Post
    Fascinating I see that too.
    Thanks,
    David L. Aery
Drawing a spline
Drawing a spline
