Need Help! V31 Post Processor question
Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: V31 Post Processor question
    Oct 2013
    Default V31 Post Processor question
    I'm planning on doing some 4 axis routing with V31 and noticed that the NC code had "B0" without a move command near the beginning on the code but no rotary axis moves where I expected them, so I dived into my Mach3 PP and noticed there is a lot of use of p_rot and s_rot variables in the move blocks but these never seem to output any information. I checked the Post Variable and API doc and it does include the p_rot and s_rot variable but I couldn't get this to work so I changed all occurrences to force_prot and force_srot and now see the rotary axis commands in all moves, haven't tried this on the machine yet.
    I would like to know if anyone else has come across this issue?
    Calum
    Registered aldepoalo's Avatar
    Mar 2012
    Default Re: V31 Post Processor question
    These are variables for 5 axis machines. If you are looking to copy a post for a 4 axis mill I would start with the BC 4X post. This one is setup for a rotary table that is parallel with the X axis.
    Primary Rotation = p rot
    Secondary Rotation = s rot
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Oct 2013
    Thanks AL. I have been using BC 4X post as a reference for years but it also uses p_ and s_rot for its moves in blocks 50-57! BC 4X does use
    output_primary_rotary_index
    output_secondary_rotary_index
    in block 2 and 3 which I have not tried but the force_prot and srot seem to be working on my machine just needs more testing.
    I would have thought the G code would include something from the p_rot and s_rot respective of the number of axis unless there is a compiler switch or something in BC for what is posted to the PP!
    Cheers
    Calum
    Oct 2013
    After a couple of days investigating this I have found that the original p_rot and s_rot do output move info when feed_mode is used on each feed block, this was missing in the Mach PP so I dumped it and started customizing the BC 4x PP. This seems to be working fine but the indexing/rotational angle for the 4th axis freezes at the end of a long rotary feature and I can't get indexing to move the axis unless there is a tool change but I can live with this for now.
    Calum
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by Calum View Post
    Calum
    For longer rotary jobs, i hit the limit that is set on the machine definition for the bc 4 axis machine. I always jack this up a bit.
    If you go into the machine definition and select the axis, it is usually set to something like 10,000.
    See if that is your freeze point....
    Oct 2013
    Thanks BureMan, I did discover this myself and have set my machine limit to something like 1,000,000 so that's not my issue now. At the end of this job the machine is at something like 113,000 degrees but when I want to set an index to 90 deg it sends 116,000 not 90. In my PP I have tried a G28 at the end of each operation with and without a tool change and this returns all axis to home but the BC still has the high degrees for the 4th axis! The only way I have been able to change this is with a tool change then I can get on with indexing.
    More to learn yet I think.
    Cheers
    Calum
  7. #7
    Dec 2008
    Cheers
    Calum
    There is a setting to output 0-360 only.. rinse lather and repeat...
    Are you aware of this?
  8. #8
    Oct 2013
    Sorry about the typo in your handle in my last reply Burr.
    Yes I did try that a year or two ago but can't remember why it didn't work for me, I'll give it another go now I know a bit more.
  9. #9
    Oct 2013
    After some more investigation it seems I can get indexing working after a 4 axis rotary feature if I select Zig Zag in the 4 Axis Rotary Patterns but only with Style=Around. This won't work if Style=Along or Zig only or Spiral! Is this a bug in BC v31? Haven't tried in any other version.
    All works fine if I do a tool change before the first indexing feature after the 4 Axis Rotary.
  10. #10
    Dec 2008
    If you want, zip and attach your post pricessor and a bbcd file that can create what you are looking at and i will look at it with you.
  11. #11
    Dec 2008
    Are you adding an "index system" after the rotary feature ir just trying to change it within a feature?
    The bbcd file will help.
  12. #12
    Oct 2013
    Hi Burr, no I'm not adding an "index system", I did try that but it didn't seem to do much although I don't know how this works.
    I have zipped my PP and bbcd files and would appreciate any insight you have if you have the time.
    Cheers
    Calum
    Attached Files Attached Files
