1) Unable to find a way to add icons for a function to tool bar. I especially miss the undo redo buttons. Yeah, ctl z works, but still.....
You will find undo and redo at the top of the screen
2) Also want to add a ISO9 view to tool bar - don't see how
It doesn't look like we offer an ISO9 option. I check V30 and V31 and I do not see this option. I will put a request into development to add this view.
3) AND THIS IS THE BIG ONE.....
Wire EDM path - when using a glue stop you should be able to do the following:
Rough pass (Leave glue stop)
finish pass(es) (respect glue stop)
M01 to pause
Remove glue stop
finish pass on glue stop ONLY. <------ This fails - re-finishes the entire path instead of only the glue stop!
If you could fix this, I will send you a bottle of decent scotch. I have been asking for this for several years.
If you re order you operations where the tab comes last you'll get the result you are after. For more information on this topic I recommend a one on one demo.
Code:
L100 / BOBCAD1-MAIN-RUN
(MACHINE,MITSUBISHI,FA,Series,)
(CREATED-MON.,09/24/2018,11:19AM,)
N0001 M122
N0002 G90 G00 X0. Y0.
N0003 G92 X0. Y0.
N0004 M20 M78
N0005 M80 M82 M84
N0006 E421
N0007 H1=.008
(FEATURE,EDM,2X,INSIDE,2,AXIS,ROUGH,CUT,FORWARD)
N0008 G01 G41 X0. Y.25 H1 F.234 M90
N0009 G01 X-.75 Y.25
N0010 G03 X-1. Y0. I0. J-.25
N0011 G01 X-1. Y-1.5
N0012 G03 X-.75 Y-1.75 I.25 J0.
N0013 G01 X.75 Y-1.75
N0014 G03 X1. Y-1.5 I0. J.25
N0015 G01 X1. Y0.
N0016 G03 X.75 Y.25 I-.25 J0.
N0017 G01 X.1 Y.25
N0018 G01 G40 X.1 Y.2 M91
N0019 M00 M91 F30.
N0020 G01 X0. Y0.
N0021 M00 M90
N0022 E622
N0023 H1=.0053
(FEATURE,EDM,2X,INSIDE,2,AXIS,SKIM,CUT,1,FORWARD)
N0024 G01 G41 X0. Y0. H1 F.256 M90
N0025 G01 X0. Y.25
N0026 G01 X-.75 Y.25
N0027 G03 X-1. Y0. I0. J-.25
N0028 G01 X-1. Y-1.5
N0029 G03 X-.75 Y-1.75 I.25 J0.
N0030 G01 X.75 Y-1.75
N0031 G03 X1. Y-1.5 I0. J.25
N0032 G01 X1. Y0.
N0033 G03 X.75 Y.25 I-.25 J0.
N0034 G01 G40 X.1 Y.25 M91
N0035 G01 X.1 Y.2
N0036 M00
N0037 M91 F30.
N0038 G01 X0. Y0.
N0039 M00 M90
N0040 E421
N0041 H1=.008
(FEATURE,EDM,2X,INSIDE,2,AXIS,TAB,CUT,FORWARD)
N0042 G01 G41 X0. Y0. H1 F.234 M90
N0043 G01 X.1 Y.25
N0044 G01 G40 X0. Y.25 M91
N0045 G01 X0. Y.15
N0046 M00
N0047 M00
N0048 M21
N0049 M02
