For the little amount of CNC machining I do I've been happy to continue using BobCad V21.4 except that recently I'm unable to peck drill.
Normally I'd select a point or points on the 2D drawing then Machine, Drill and Cycles which brings up the Execute Cycle dialog box and I select G73 Peck Drill after which the G73 Parameters box comes up, but now the G73 Parameters dialogue box no longer opens so no code is generated. Any thoughts on what I'm missing?
