Problem NPT thread milling crash
Results 1 to 4 of 4
Thread: NPT thread milling crash
    Aug 2010
    canada
    Default NPT thread milling crash
    i have programmed a very simple 1/2"-14 NPT thread, upon generating the tool path everything looks great!
    but, when i simulate it, it makes moves that are not shown in the tool path and crashes.
    Any help would be greatly appreciated.
    .zip file attached
    Attached Files Attached Files
    Member L98FIERO's Avatar
    May 2003
    Keswick, Ontario
    Default Re: NPT thread milling crash
    There was no workpiece in your file but after I created one it would post a good file when I checked it with backplot and CNCdiscriminator. I've had issues with the simulator sometimes doing odd things with other files before too and I could not even get this file to run in the simulator (V30 with the latest update). From what I could see it couldn't figure out how to build the proper tool and to make sure I did check yours as well.
    Aug 2010
    canada
    I simulated it in my mill and it ran flawlessly..... weird.
    Aug 2008
    I get 17,000 lines of G-code to cut that. Ridiculous for one threaded hole. Arcs or lines does not matter, V32.
