How big ?
Helical,meaning both sides parallel as it ramps up ?
This is not what I want but you should get the idea. I need a spiral ramp. I don’t know how to.
What is the procedure
Rob
- - - Updated - - -
I also need it to go 180 degrees not 90
- Extrude a cut?
- Need Help!- Extrude Gear
- Need Help!- Extrude cut
- Need Help!- Can't extrude.
- Need Help!- how to extrude
How big ?
If this is what you need I used to spiral a inner and a outer and connected them with a line and then skinned then extruded the surface for thickness and then added to a cylinder. (Have the output set arcs when doing the spirals)
Kind of a Paine but it seems to work there may be easier ways
RAF.
