Need Help! V-29 FILE
Results 1 to 13 of 13
Thread: V-29 FILE
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by 1234567 View Post
    When i try to reopen this file it wont display anything in the graphics window . it shows the entities are there blanked. help!!!!
    I havent opened your file. First thing i would try is to select all, then create a new doc and paste.
    Mar 2009
    Default Re: V-29 FILE
    ill give it a try, thanks Burr
    Mar 2009
    must be something wrong with the file. when i copy and pasted nothing showed up. but it says the entities are there.
    Attached Thumbnails Attached Thumbnails V-29 FILE-capture-jpg
    Dec 2008
    Next try is save as iges and sat and see if new file opens entities showing.
    Apr 2009
    Opens fine and all layers work
    Hmmmm,
    I am running only Demo mode in V29,so I can't save it
    Hmmmm
  7. #7
    Mar 2009
    bob cad crashes when i try to save as iges or sat. all my other files seem to work just fine. weird
    - - - Updated - - -
    so strange.
  8. #8
    Mar 2009
    jrmach well get the full version hahaha
  9. #9
    Dec 2008
    When you tried to copy and paste, did you paste in a new dic, or the same one?
    I can try open and convert to recover for you, but i am a couple days away from computer. If anyone else can do it before, good.
    Btw. Be sure to look in backup dir for a same named file to try open, if it exists....
  10. #10
    Mar 2009
    ok thanks, even if i can just get the layer named" new profile" as a dxf or something that would be very helpful.
  11. #11
    Mar 2009
    ok recovered the profile i needed. i did the select all on just that layer and it showed up in the new file. I can remodel off of that. thanks for your time guys!
  12. #12
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    I wasn`t able to open your file in V29 (Demo) fulll version, however it opens fine in V30 (Demo) full version and I was able to copy and paste the new profile layer into my good old trusty V28 and I have saved it out as a .DXF file for you and attached it below
    Hope it works for you, I tried the same with the solids but it just crashed V30 so looks like that`s all I can get out of the file, well and truly corrupted somehow !!
    Regards
    Rob
    Attached Files Attached Files
  13. #13
    Mar 2009
    Thanks Rob.
V-29 FILE
V-29 FILE
