When i try to reopen this file it wont display anything in the graphics window . it shows the entities are there blanked. help!!!!
- How to Merge Init file with external buttons file.
- converting a .sldprt solidworks file into a .stp or parasolid file
- Windows x64 text file splitter that goes by lines, not file size?
- How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
- Need Help!- using a data file for both 3D printer and CNC router , Converting file or ???
ill give it a try, thanks Burr
must be something wrong with the file. when i copy and pasted nothing showed up. but it says the entities are there.
Opens fine and all layers work
Hmmmm,
I am running only Demo mode in V29,so I can't save it
Hmmmm
bob cad crashes when i try to save as iges or sat. all my other files seem to work just fine. weird
- - - Updated - - -
so strange.
jrmach well get the full version hahaha
When you tried to copy and paste, did you paste in a new dic, or the same one?
I can try open and convert to recover for you, but i am a couple days away from computer. If anyone else can do it before, good.
Btw. Be sure to look in backup dir for a same named file to try open, if it exists....
ok thanks, even if i can just get the layer named" new profile" as a dxf or something that would be very helpful.
ok recovered the profile i needed. i did the select all on just that layer and it showed up in the new file. I can remodel off of that. thanks for your time guys!
I wasn`t able to open your file in V29 (Demo) fulll version, however it opens fine in V30 (Demo) full version and I was able to copy and paste the new profile layer into my good old trusty V28 and I have saved it out as a .DXF file for you and attached it below
Hope it works for you, I tried the same with the solids but it just crashed V30 so looks like that`s all I can get out of the file, well and truly corrupted somehow !!
Regards
Rob
Thanks Rob.
