Your head hurts? How do you think ours feel, just been online and bought shares in the firm that make Asprin
Yes, you`ve got it, the start of the feed cut at DOC (assuming that you actually set one, otherwise the software will use it` own default)
Here is some more "pain" for you just in case you haven`t noticed why I used the values I did.
You wanted a DOC of 0.25" but didn`t want a zig zag ramp, just a little math will do it for you, if a longer shallower ramp is desired then remember that a straight plunge is at 90 Degrees to the plane so a 1.0" distance ramp from plunge point going to a 0.25 DOC, then as 0.25 is a quarter of 90 therefore a quarter of 90 degrees is a ramp angle of 22.5 degrees which will give a single ramp in without any zig zag as in the example
Hope that`s enough for you for today, keep taking the pills
Regards
Rob
