Sorry, I haven`t found a quick/easy way of clearing out the default tools, I have to as I work also only in Metric so none of the default (Inches) tools are of any use to me, a real pain, I have been asking for several years now for BobCAD to come with either no tools at all or a choice of Inches or Metric Tool Library
You can set up individual Tool Cribs for each machine so when you start a new job in BC you can select a specific Tool Crib at the start and then when you create features the only tooling available will be from the Crib you selected
You can "Copy and Paste" the Tool Library file across to another PC, so if you are on a Network you should be able to do it from the main location.
Don`t know what you have in the way of IT people but it may be possible to access a single (Main PC) Tool Library from other stations but I couldn`t tell you how to do it, worth asking your IT people ?
Regards
Rob
:rainfro: :rainfro: :rainfro:
