Need Help! tranlate
Results 1 to 9 of 9
Thread: tranlate
    Apr 2009
    Default tranlate
    Build 1547 V27
    Translate drag does not work
    Translate Delta is no longer there
    Anyone else ?
    Let me re-word it,it does not work in a user friendly way.
    Feb 2013
    United Kingdom
    Default Re: tranlate
    I've read the build notes and there's no mention of problems in Translate -
    http://bobcad.com/wp-content/uploads...Build_1547.pdf
    - Nick
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
    Apr 2009
    Have you tried it ?
    It works but is lame
    maybe it will get better once use to it,,,I hope
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    I have Build 1462 and the drag and Delta work fine here, must be one of those "do something new and break something old" that they seem to be fond of doing
    The translate has been solid since V23 from my recollection
    Regards
    Rob
    :raifro:
    Member Hood's Avatar
    Oct 2004
    Scotland
    Using 1547 but hardly ever use translate so not sure if its not as good as before but drag seems to be working fine.
    Just opened a solid in BobCAD, clicked translate then selected the model, right click OK then the coords handle pop up and I can drag no problem. Maybe it was different before?
    Hood
    Ghost BurrMan's Avatar
    Dec 2008
    Could be a case of "got myself a new computer and video card".....
  7. #7
    Aug 2007
    U.K
    I am on build 1547 and it does not work as it did for me either.
    The drag button appears to do what the delta did, but no other option for delta/drag available.
  8. #8
    Sep 2014
    Jrmach....Translate drag works...but differently. I had the same question and someone at bobcad enlightened me. I have V27 build 1547. Translate drag...start the command, pick what you want to move and do you see the little ball at the center of the XYZ icon?.....select the ball and you can move the item you selected. Also on translate delta...select the sketch/enter command and have start pick and end pick set to the enter button. Then it is a full delta move. Hope this helps. Have a great day.
  9. #9
    Member LeWhite's Avatar
    Dec 2011
    I like the translate of V27.0.0 better than build 1547.... If anybody important cares!
tranlate
tranlate
tranlate
