I can't open it with V25, what version are you using?
- Nick
Can somebody please look at this and tell me what is wrong? I can't get a toolpath around the outside. I've done this a million times!
- Nick
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
What Build of V27 are you using?
Go to Help/about Bobcad,,should have a build number there
Hmm. Thanks jrmach. So there is a problem with the radius and the lines connecting at the tangency? I hadn't considering using a contour to help spot it. Thanks again.
Yeah it is a very,very small gap.
Another thing you could of done was change your CAM tolerance under preferences/part..Change from .0001 to .001 and all is well then.
If something does not tool path,,,it's geometry problems usually.
