Problem improper vacuum hole placement on router tables to accommodate 48x96
Results 1 to 2 of 2
Thread: improper vacuum hole placement on router tables to accommodate 48x96
    Apr 2014
    Default improper vacuum hole placement on router tables to accommodate 48x96
    A number of people have complained that on router tables of sizes bigger than 1224 material sheet, the vacuum zone holes do not allow for complete suction. This is because of the aluminum T slot locations.
    If you consider 5 slots, numbers #2 and #4 prevent placement of 1224 material ( the most common size here in North America) properly.
    Why can't this be changed already? I brought it up 2-3 years ago.
    Member elephantcnc's Avatar
    Nov 2011
    shandong
    Default Re: improper vacuum hole placement on router tables to accommodate 48x96
    Is it our machine? If yes, please leave your email or whatsapp. Our technical support will contact you.
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
