ATC Nesting Machine with Automatic Loading and Unloading Platform
Results 1 to 1 of 1
Thread: ATC Nesting Machine with Automatic Loading and Unloading Platform
    Cool ATC Nesting Machine with Automatic Loading and Unloading Platform
    #nestingcncmachine
    ATC Nesting Machine with Automatic Loading and Unloading Platform-800x533-_2-jpg
    ATC Nesting Machine with Automatic Loading and Unloading Platform-800x533-_1-jpg
    #Working Area 1300x2500x200mm
    #Spindle ATC 9.6KW Italy original HSD spindle, ES951 Model. 6000-24000RPM
    #Control system Taiwan SYNTEC 60WE control system with MPG handle wheel, more precision
    #Drive system Japan YASKAWA 850W servo motor and drivers, Z axis with brand brake.
    #Japan Shimpo reducer.
    #Inverter Taiwan Delta B Model 11.0KW
    #Machine Frame New type thicker and bigger heavy duty 8 mm
    #Working table Vacuum table with T slot, 4 Zones
    #Tool Magazine 12 pieces with Carousel Tools Changer
    #Guide rail Taiwan PMI linear guide, 25#
    #Transmission X,Y-helical rack pinion, Z axis with 2505 TBI ball screw
    #Tool sensor Automatic tool sensor
    #Collect ISO30 tool holders with ER32 collect
    #Lubrication system Automatic lubrication system for rails
    #Traveling speed 65m/min
    #Working speed 25m/min
    #Voltage 380V,3phase, 50HZ
    #Limited switch Japan Omron limited switch
    #Electric part French SCHNERDER switch
    #Electric Wires High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand
    #Vacuum Pump German KVT3.140 4.0KW Becker vacuum pump
    #Dust Collector 1.5kw double bags dust collector system. Europe CE standard
    #Drilling Head Italy HSD 9 vertical type
    Attached Thumbnails Attached Thumbnails ATC Nesting Machine with Automatic Loading and Unloading Platform-800x533-_-2-jpg   ATC Nesting Machine with Automatic Loading and Unloading Platform-800x533-_2-jpg   ATC Nesting Machine with Automatic Loading and Unloading Platform-800x533-_1-jpg
    To be first brand CNC Manufacturer & Wholesaler platform.
    --------Jinan Blue Elephant CNC Machinery Co., Ltd--------
