Just In Wood Routing Machine Price Woodworking Machine Automatic Cnc Router
Results 1 to 1 of 1
Thread: Wood Routing Machine Price Woodworking Machine Automatic Cnc Router
    Cool Wood Routing Machine Price Woodworking Machine Automatic Cnc Router
    #atccncrouter
    Wood Routing Machine Price Woodworking Machine Automatic Cnc Router-800x533-_2-jpg
    Working Area 1300x2500x200mm
    Spindle ATC 9.6KW Italy original HSD spindle, ES951 Model. 6000-24000RPM
    Control system Taiwan SYNTEC 60WE control system with MPG handle wheel, more precision
    Drive system Japan YASKAWA 850W servo motor and drivers, Z axis with brand brake.
    Japan Shimpo reducer.
    Inverter Taiwan Delta B Model 11.0KW
    Machine Frame New type thicker and bigger heavy duty 8 mm
    Working table Vacuum table with T slot, 4 Zones
    Tool Magazine 12 pieces with Carousel Tools Changer
    Guide rail Taiwan PMI linear guide, 25#
    Transmission X,Y-helical rack pinion, Z axis with 2505 TBI ball screw
    Tool sensor Automatic tool sensor
    Collect ISO30 tool holders with ER32 collect
    Lubrication system Automatic lubrication system for rails
    Traveling speed 65m/min
    Working speed 25m/min
    Voltage 380V,3phase, 50HZ
    Limited switch Japan Omron limited switch
    Electric part French SCHNERDER switch
    Electric Wires High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand
    Vacuum Pump German KVT3.140 4.0KW Becker vacuum pump
    Dust Collector 1.5kw double bags dust collector system. Europe CE standard
    Drilling Head Italy HSD 9 vertical type
    Attached Thumbnails Attached Thumbnails Wood Routing Machine Price Woodworking Machine Automatic Cnc Router-800x533-_2-jpg
    To be first brand CNC Manufacturer & Wholesaler platform.
    --------Jinan Blue Elephant CNC Machinery Co., Ltd--------
