#ATCCNCWoodMachine
4 Axis CNC Router with Automatic Tool Changer-800x533-_-2-jpg
Model-2128ATC-4A with CE certificated
# With effective working area is 2100*2800*500mm;
# machine frame is the newest design more stronger
#working table: with vacuum and T slot design
# 9.6kw Italy original HSD air cooling spindle; 24000rpm;
# the spindle rotate ±90 degree;
# Taiwan Delta inverter 11kw, VDF-B;
# Japan Yaskawa 850w servo motor and 1000w drivers;
# one set 750w Japan yaskawa for the 4th axis.
# Taiwan Syntec 6MB controller with 1.8m controller box;
# 8pcs Linear tool magazine with 8pcs ISO30 tool holder
# X,Y-helical rack pinion , Taiwan J&T 1.5M ,Z ball screw
# TBI ball screw from Taiwan
# Japan Shimpo reducer , total 3sets;
# Automatic tool sensor with protection cover;
# Total 3pcs E-stop, one in controller box, two in y1, y2 axis motor cover
# 7.5kw air blower vacuum pump , 3.140, kvt ,two sets;
# ER32 collet , 3.175 mm, 6mm, 12.7mm, 20mm;
# Automatic lubrication system for rails ,1.5L auto setting type;
# UG software POWER Mill free & post processor;
