#nestingcncmachine
#1300x2500x200mm effective working area, table sank 200mm;
#Original Italian HSD4.5KW Air Cooling Spindle, Pneumatic 2 spindles;
#Taiwan DELTA 7.5KW inverter, top brand;
#Taiwan LNC MW220 controller, support 4 axis;
#Chinese Leadshine 850W servo motor and drivers;
#Chinese Newgear reducer, 2 on Y axis, and 1 on X axis
#T-slot and Vacuum Table
#Taiwan PMI Linear guide and rails, 25mm
#Welded machine structure, heavy duty machine body, new design;
#X,Y-helical rack pinion, Z axis with TBI ball screw
#High soft shield with copper wire to protect against static electricity, Shanghai Cardiff/German Igus brand
#Japan Omron limited switch
#Auto tool sensor
#Automatic lubrication system
#French SCHNEIDER switch
#1.5KW double bags dust collector
#Chinese JQT 5.5KW Air Vacuum Pump, double stage, two blower;
#1.5KW double bags dust collector with CE certificate;
E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
--------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
