Automatic Nesting CNC Machine with auto loading unloading table
# 1300x2500x200mm effective working area, table sank 200mm;
# Original Italian HSD4.5KW Air Cooling Spindle, Pneumatic 2 spindles;
#Taiwan DELTA 7.5KW inverter, top brand;
#Taiwan LNC MW220 controller, support 4 axis;
#Chinese Leadshine 850W servo motor and drivers;
# Chinese Newgear reducer, 2 on Y axis, and 1 on X axis
#T-slot and Vacuum Table
#Taiwan PMI Linear guide and rails, 25mm
# Welded machine structure, heavy duty machine body, new design;
#X,Y-helical rack pinion, Z axis with TBI ball screw
#High soft shield with copper wire to protect against static electricity, Shanghai Cardiff/German Igus brand
#Japan Omron limited switch
#Auto tool sensor
#Automatic lubrication system
#French SCHNEIDER switch
#1.5KW double bags dust collector
# Chinese JQT 5.5KW Air Vacuum Pump, double stage, two blower;
# 1.5KW double bags dust collector with CE certificate;
#Machine Auto Loading and Loading system Lifting tablet, Autoloading components of the CNC router Unloading table
# E-stop buttons;
#Artcam/Aspire control software;
#Positioning Pop-up Pins, 2 on X axis, 3 on Y axis
#380V±10%, 3 phase, 50Hz
- Just In Automatic tool changer nesting cnc Drilling holes CNC machine for wood door carving
- Just IN- automatic cnc router nesting cnc machine with auxiliary feeding platform for wood
- Just IN- New 2130 automatic wooden furniture making machine cnc nesting machine with labeling
- Problem- automatic nesting from design2fab to torchmate cad
To be first brand CNC Manufacturer & Wholesaler platform.
--------Jinan Blue Elephant CNC Machinery Co., Ltd--------
