Customized atc cnc Drilling machine with Italy HSD C axis
#Working Area 1560x3200x400mm
#Spindle ATC 9.0KW Italy original HSD spindle, ES951 Model. 6000-24000RPM, HSK-63F tool holders;
#Control system Taiwan SYNTEC21MA control system with MPG handle wheel, more precision, Max support 6 axis
#Drive system Japan YASKAWA 1.3KW servo motor and drivers with Japan Shimpo reducer, Z axis with brake function
#Inverter Taiwan Delta B Model 11.0KW
#Machine Frame New type thicker and bigger heavy duty 8 mm. Bigger gantry 300*300mm
#Working table Vacuum table
#Tool Magazine Linear ATC with 7 tools + Circle ATC with 12 normal tools 19pcs HSK-63 tool holders included
#Guide rail Taiwan PMI linear guide, 30#
#Transmission X,Y-helical rack pinion, Z axis with 2510 TBI ball screw
#Tool sensor Automatic tool sensor
#C axis Italy HSD C axis with Japan Yaskawa 400w Servo motors
#Lubrication system Automatic lubrication system for rails, ball etc
#Boring Head Italy HSD BHZ24 Boring Head, 8vert+5vert / 5 hor / 1 blade
#Traveling speed 65m/min
#Working speed 25m/min
#Voltage 380V,3phase, 50HZ
#Limited switch Japan Omron limited switch
#Electric part French SCHNERDER switch
#Electric Wires High soft shield with copper wire to protect against static electricity, UL/CE standard Shanghai Cardiff brand.
To be first brand CNC Manufacturer & Wholesaler platform.
--------Jinan Blue Elephant CNC Machinery Co., Ltd--------
