1530 cnc 3d wood carving machines with air cooling spindle
# Effect work size:1500*3000*300mm # 6kw Italy HSD air cooling spindle
# 7.5kw Taiwan Delta inverter
# 300mm diameter and 3000mm length of rotary device fixed on Y axis
# 750w Japan Yaskawa servo motor and driver for X,Y,Z axis; Stepper motor and driver for rotary device
# RichAuto DSP B18 control system # T-slot & vacuum working table
# Working voltage: 380v, 3ph, 50hz # 7.5kw water circulation vacuum pump (380v, 3ph, 50hz)
# 1.5kw new type double bag dust collector (380v, 3ph, 50hz)
# Taiwan linear guide rails, #20 for X,Y,Z axis
# Helical rack gears transmission on X,Y axis
# Taiwan TBI ball screw transmission on Z axis
# Artcam software
# Highly flexible towline, fire-resistant double-sheathed cable
# Seperate control box with 2 doors
To be first brand CNC Manufacturer & Wholesaler platform.
--------Jinan Blue Elephant CNC Machinery Co., Ltd--------
