Small cnc router machine with 4th rotary device
#600*900*500mm effective working area
#3KW water cooling spindle 0-24000 rpm
#3.7kw Fulinginverter VFD
# DSP B18 control system for 4 axis
#300mm diameter of Rotary device ,length 900mm
#Taiwan PMI linear guide way for X,Y,Z axis
#Helical rack gears for X,Y axis
#Taiwan TBI ball screw for Z axis
#France Schneider safety switch
#Leadshine 750w easy servo motor and driver ,4 sets
#FL118 motor and Yako 2811 bigger driver(for rotary device), 1 set
#Manual oil lubrication system
#Japan OMRON limit switch for X,Y,Z axis
#1.5kw the new type dust collector with CE certificate
#Soft limit switch
# Shanghai Cardiff cable
#Artcam software
To be first brand CNC Manufacturer & Wholesaler platform.
--------Jinan Blue Elephant CNC Machinery Co., Ltd--------
