- Just In Working principle and classification of CNC nesting machine
CNC nesting machine is automation equipment mainly used in the production and processing of common plate-type furniture cabinets, wardrobes, tatami mats, and office furniture. It can also be applied to advertising carving, mold milling, musical instruments and crafts carving. Its main working principles: The precision electric spindle drives the milling cutter to rotate at high speed to complete drilling, cutting, engraving and other processing. It is used in the plate processing industry. The common table uses the form of plate fixing and the gantry movement of the machine head. The woodworking CNC opener is a kind of Three-axis numerical control engraving processing equipment, which can drill, slot, slit, engraving and milling in the plane.
- You may not post replies
- You may not edit your posts
Forum Rules
