- The secrets about the choice of motor power of CNC router spindle
“The higher the power of the spindle motor, the better the processing effect and the higher the production efficiency." Have you heard of this word before you purchase a CNC router?
Blue Elephant wants to tell everyone, don't be deceived by this unreal rumor, the selection criterion of spindle motor power is to meet your own processing needs. Depending on the processing material, too higher power can not achieve better processing results. On the contrary, it will increase the cost of purchasing the enterprise. Follow Blue Elephant to learn how to choose the power of spindle motor.
For the advertising engraving machine, since the processing materials are mostly soft materials, such as PVC, acrylic, MDF, etc., in order to achieve the double purpose of engraving effect and cost saving, the spindle power is most suitable from 1.5kw to 3.0kw.
- You may not post replies
- You may not edit your posts
Forum Rules
