Is a DIY aluminium extrusion machine feasible?
Results 1 to 2 of 2
Thread: Is a DIY aluminium extrusion machine feasible?
    Apr 2007
    Norway
    Default Is a DIY aluminium extrusion machine feasible?
    Hi. Today tabletop extruderscrew plastic injection molding machines for the homeshop is a reality. But what about aluminium extrusion machines? Is is feasible to build a aluminium extrusion machine at home?
    In principal it looks pretty straight forward. Just a pipe with a die in the end and a ram with a hydraulic drive and some form of heating to heat the aluminium billett.
    So can it be made in she home shop for prototyping? And how much force is typically needed (assuming we use smaller diameter billetts than in normal production machines). And is it practical to make larger diameter extruded parts than the billett used? Maybe via a multi stage die.
    I got the idea because i wanted to experiment with some different aerofoil profiles for a project i have. And want to make them out of extruded aluminium so they can be hollow with structural ribs on the inside.
    Jun 2007
    canada
    Default Re: Is a DIY aluminium extrusion machine feasible?
    on a micro scale, maybe. most of the extrusion machines ive seen are bigger than my house
    ewrret's Avatar
    Jan 2021
    Extruders are relatively large, so you must pay attention to temperature and humidity during execution
    Plastic molding experts
    https://www.tigerkj.com/en/industry-...ection-molding
