Give LVD a call they should be able to troubleshoot it... I was up at their facility last week in Buffalo... Most parts are being made in the usa now...
Does anyone out there have any ideas as to what might be causing the pressbrake to "shudder" on the downstroke - no problem during the freefall part but once it passes the mute point it seems like the pressure isn't being maintained. Also the machine won't calibrate the tool in "Production Mode". Any suggestions gratefully received!
- Parting an R2E4 Series II control - any interest in the complete control panel?
- Cincinatti Arrow 500 Emerson Control Techniques control parts for sale....
- Cards Support Stepper Motor Driver Control & AC Servo Control.
- 15i control help for (AiCC) (hpcc) high precision contour control programming
- Using Flashcut CNC Spindle rotate card control to control laser power
Thanks for the suggestion .... unfortunately we aren't based in the USA.
I was at there facility today... They are more then helpful if you give them a call..
Did you change springs on the prefill valves?
If machine is old, it can be that springs are tired (or broken).
Better to change both springs on the prefill valves on the old machines. (10 years and more).
I am sure that your machine will work ok after that a long time.
timur123@gmail.com
In trumpf v 85 s we had the same problem
Its propotional valve problem at oure machine and the oil was old roynd 17000 hours
Chanche new oil new propotional valve and new oil filter
Machine ok
Hope you repair yoy machine
