Forged 6061-t versus 7075-t651
Results 1 to 5 of 5
Thread: Forged 6061-t versus 7075-t651
    Registered lourenco's Avatar
    Dec 2007
    Brasil
    Default Forged 6061-t versus 7075-t651
    Hi Guys , i have been working in a racing billet brake calipers to my racing team.
    Now the design is read to be machined ,but i have some questions...
    Why the most billet calipers are maden from aluminium forged 6061-t ????
    I cant make forging process in my shop, so i guess, if i could use the 7075-t651 instead of forged 6061???
    Why do they use 6061 so much ? Is it a cheapest material?
    What is the hardness brineel diferences between 7075-t651 and forged 6061-t?
    Its easy to find 7075-t651 in my country (Brazil) ,the 6061 i cant find, only importing....
    Thanks guys
    Jul 2005
    Here are a couple of links with information about 7075 and 6061. I think 6061 is used because it is cheaper than 7075 and is widely available in North America. I also think anything that can be made out of 6061 can probably be made from 7075 without any problems other than 7075 not being as corrosion resistant as 6061.
    http://www.unitedaluminum.com/aaa.php
    http://en.wikipedia.org/wiki/7075_aluminium_alloy
    Dec 2007
    Brasil
    i have a question...
    what is the strongest aluminium ??? forged 6061-t or 7075-t651???
    6061-t651=95 brinnel
    7075-t651=150 brinnel
    forged 6061=??????
    How much brinnel hardness increase the forging process on 6061??
    thanks
    Registered dodo34's Avatar
    Jul 2018
    Default Re: Forged 6061-t versus 7075-t651
    Hello Lourenco,
    have you found out which one is good ?
    Do you need help ?
    Kind regards
    Member Cvitanic's Avatar
    May 2018
    Punta Arenas
    Quote Originally Posted by lourenco View Post
    Thanks guys
    Hi Lourenco, How easy is it to find 7075 in Brazil ? I need machinable Aluminum but can't seem to find anything but Al 2021 in Chile. I would consider importing 7075 from Brazil, so where would I find it, and roughly what's the price per kg ?
    Thanks for your help !
