Originally Posted by
norin1373
Hi
Your machine turret is Triple track, it means there are three tool set in a row with the same index pin. 1xx tools are inner, 2xx are center and 3xx are outer track. So they have a Y axis offset with each other.
You can use
G70“machine home position” T 2xx
Or simply don’t use machine home position at G70 line. Subtract Y axis offset from Y value.
Ex:
G70 X1830. Y1200.
M00
But in this case the X gauge block may not raise.
Mail me if the problem was not solved.
Norin1373@yahoo.com
Good luck
Thank you!
This makes perfect sense and it solved my issue.
I changed
Code:
G70 X78.74 Y50.75
M00
to
Code:
G70 X78.74 Y50.75 T229
M00
T229 was the next tool in the sequence, so it seemed a logical choice. The carriage returned to the home position and the operator was able to raise the x gauge block and reposition the sheet before resuming. We did a dry run first with punching off and then again with punching off just for the first stage, since we already had one part that had finished the first stage before triggering the OT+ error. We turned punching back on for the remainder of the program and it executed flawlessly.
Thanks again!
