- AMADA NC9-EXii alarm code 408 (on RG100)
Hello,
I have an amada rg100 with the NC9-EXii cnc controller. I have the manual for both the controller and the machine.
(my apologies, but I am a noob)
While working through the manual on how to program the controller, I entered all the data for the
V opening
Thickness
Tensile Strength
Punch Radius
Die Radius
Die Angle
W Flange Dimension
Angle
Bend Length
When I press INP to input this into my process, it ALARMS with 4 08
I assume there is an error I am doing in entering my data?
is there a list of error codes available for this controller? My google-fu was not able to find one.
Re: AMADA NC9-EXii alarm code 408 (on RG100)
Ah found it, it was in the manual
alarm 4f08 my angle calc is incorrect.. now to go figure that out...
- You may not post replies
- You may not edit your posts
Forum Rules
