- Amada ball transfer units
Hi everyone. We bought a second hand Amada CNC turret punch machines. On the tables, brushes are there but ball units are missing, only the ones on the central part are still there. Previous owners only used small thickness sheets (1 mm) but in our case up to 3.2 mm will be needed.
Replacement parts are hard to find here, so I would like your advise on whether we should get this thing right or it is not a big issue.
- You may not post replies
- You may not edit your posts
Forum Rules
