- Amada RG-80 with Hurco Autobend 7
Hi ppls, not sure if I'm posting in the right section
Using an Amada RG-80, I don't have that much time on it, but it seems like a good machine
One problem, it's an Up-acting lower beam machine... I can't seem to set the lower limit setting with the lever on the front of
machine....When the lower beam is at a height that is more suitable for parts being bent I'm assuming I push the lever to the down position
The problem is it doesn't seem to do anything, the lower beam goes all the way to bottom stroke
I can set the speed no problem with the other lever in behind it but I would like to get that low limit lever working
Any thoughts?
Thanks, Bill
Re: Amada RG-80 with Hurco Autobend 7
Almost forgot about this post
It was an easy fix... pulled the front cover off and lubed some parts that lock the height in place
- You may not post replies
- You may not edit your posts
Forum Rules
