Press Brake / 8mm U-channel
Results 1 to 1 of 1
Thread: Press Brake / 8mm U-channel
    Member MJRx's Avatar
    Jun 2021
    Default Press Brake / 8mm U-channel
    Hi, I'm looking at buying some equipment for bending an 8mm U-channel.
    The material I want to bend would be Copper / Stainless steel ~max 1mm (length max 20cm)
    The wall height of the folded part is around ~8mm (but on the outer side there will be some overhang up to 25mm which won't be part of the folding (it's for fixing the part to an object).
    So far I'm looking into following items:
    aliexpress.com/item/32950918112.html
    aliexpress.com/item/1005002447210850.html
    (maybe with a goose neck tool?)
    Can anyone give me some feedback about that? Are those tools suitable for it or is there a better way?
