- Amada BRAKE PRESS FBD 1030 WILL NOT START
Hi all,
Have an Amada FBD 1030 that will not start. With NC9-F
Tried to do an origin start a few days ago. The back gauge moved properly and into place, but when setting the tonnage, the tonnage was not registering the pressure as the die engaged with the punch, so I turned off the machine to try a restart.
Turned the machine back on and all of a sudden an L AXIS alarm on the screen showed up. Looked in the cabinet and both L1 & L2 servo drives displayed an OV fault.
Thinking that they somehow failed, new (rebuilt) boards were installed and appear to be working properly and the L AXIS alarm is now off, but nothing happens when I press origin start and the Hydraulic pump will not start.
D, L, YL, YR, Z,& P are all showing Zero's on the screen. I'm not sure if there should be a value at any of these when just turning the key to ON.
NC light is NOT lit and from what I recall, that should be ON when the key is turned on.
I'm wondering if I've lost parameters. Can't figure out what to do.
ANY HELP would be much appreciated. Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
