CNC99 Automec Error Codes FAIL 24, 65
Results 1 to 3 of 3
Thread: CNC99 Automec Error Codes FAIL 24, 65
    Aug 2010
    Default CNC99 Automec Error Codes FAIL 24, 65
    We recently had a power outage and our Standard Break Press with CNC99 controller is giving error codes FAIL 24 and FAIL 65.
    Can anyone give us information on these codes? Are there any places left that support this system? The autogauge /automec OEM does not support this model any more.
    Any help would be appreciated.
    Regards,
    Jack
    Member mblaszak's Avatar
    Jul 2021
    Default Re: CNC99 Automec Error Codes FAIL 24, 65
    Quote Originally Posted by PMFMAN View Post
    Regards,
    Jack
    I see nobody replied to this. I can help out if you still need it. All the "20" fault codes are a stuck key. So, Fault 20 is a stuck '0', Fault 25 is a stuck '5' key etc....
    Fail 65 is the top and bottom stroke switch both active at the same time.
    A month late but hope it helps someone
    Aug 2010
    Thanks for your reply. We sent the Unit off to Radwelll International for Repair. The unit started spitting out Help 28 code as well. Shop would hit different numbers and it would not respond or move the gauge.
    You must have seen this yourself before on your unit? This is the first issue we have had in 30 years on ours. It's been a really good machine.
    Thanks again.
    Jack
