- Amada HFB8025 bowing material
Hi Guys,
I recently purchased a used Amada HFB 8025 8' press brake. Purchased all new tooling, punch holder, punch, die rail, die. What is happening when I bend material is it is bowing it in the middle. The angle is consistent in the middle as it is on the ends, so it's not canoeing, but bowing the length of the bend. Not sure if this a common deflection issue?
Any suggestions would be appreciated.
Thank you,
Greg
Re: Amada HFB8025 bowing material
Le mien est HFBO8025 -1996.
Cependant, je recherche une version électronique de l'instruction pour la traduire en bulgare. Quelqu'un peut-il m'aider?
- You may not post replies
- You may not edit your posts
Forum Rules
