- Help needed to change language in Cybelec CNC DNC 1200 PS/A
Re: Help needed to change language in Cybelec CNC DNC 1200 PS/A
If you are in USER LEVEL 3 then the only other thing that should be required is that you are in PROGRAM mode.
I recognize that this thread is extremely old and that this person likely no longer needs and answer. But maybe this information can be helpful to somone else along the way in the future.
If you attempt to change the language in Cybelec DNC software and find that it immediately reverts back to its previous selection this almost always means that the version of Cybelec being used requires a dongle key to function and the system is not finding the security dongle. On old systems this dongle was in the form of a key that plugged into the "Printer" port on the CPU card. On newer versions this dongle key was in the form of a USB plugin that is plugged into one of the USB ports on the CPU card. In the case of this failure you either do not have a dongle security key, or the key or the port it is plugged into is not working poroperly for the dongle to be identified. You must resolve this dongle issue prior to being able to use the software.
- You may not post replies
- You may not edit your posts
Forum Rules
