- PM-25MV Spindle Drive Replacement
I am in a pickle. My spindle drive has failed on my Precision Matthews PM-25MV. The Precision Matthews support say the controller is out of stock and it could be a loooong time to get a replacement.
They won't say what the motor voltage is so I'm screwed by them unless I can determine the stock motor voltage so I can replace the drive with another.
Does anybody know a suitable drive replacement?
As far as I can tell the drive is
110 VAC input
output voltage = UNKNOWN (this is what I am looking to the community for help with)
0-2500 rpm
The current drive has a sticker on it with the name DULY.
Re: PM-25MV Spindle Drive Replacement
Nope. But I'll be replacing my drive/motor with a Delta AC servo kit at some point. Might be worth looking into.
Can you replace the spindle on the PM-25 with a BT-30 ATC Spindle?
- You may not post replies
- You may not edit your posts
Forum Rules
