Hi
welding 2 inch thick material is not easy. To get full penetration welds is likely to be really time consuming or something that should be done with sub-arc.
Once you are done you will have to thermal stress relieve or the steel will move every time you touch it. Thermal stress relief requires putting in in an oven
at something like 700C for many hours....its not cheap, and certainly not something you can do yourself.
I think welding is a mistake.
You should get a piece of steel plasma cut. I priced some plasma cut steel plate just a couple of months ago in 32mm medium tensile and found that it works out
to about $6.00NZD/kg ($4.00USD/kg). Thus a piece 200x 600 of 50mm would be about $288NZD ($175USD). If you were to go this way then stress
relief is not required although you would probably still want to grind it. I had three pieces of 375 x375 x20 done for me about a year ago and cost me $90.00NZD ($60.00USD).
Craig
