Is it OK using double ball nut on BF20L Y axis?
Results 1 to 8 of 8
Thread: Is it OK using double ball nut on BF20L Y axis?
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Is it OK using double ball nut on BF20L Y axis?
    I have my BF20L already converted to CNC but without disassemble I can't be sure if a 1605 double ball nut on the Y axis will fit or not. To be more precise will the nut hit to the base when traveling to both directions?
    Suat
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
    Mar 2014
    Turkey
    Default Re: Is it OK using double ball nut on BF20L Y axis?
    I believe G0704 owners can also answer my question.
    Suat
    Jan 2018
    United Kingdom
    Quote Originally Posted by Azalin View Post
    Suat
    I've got a PM25 clone if that's similar sizing.
    Fitted double nut to that fairly well.
    Had to remove nut to reverse it so the bolt end went to the back of the Y with motor end at the front.
    If you can, fit Angular Contact bearings too.
    https://www.cnczone.com/forums/bench...5-clone-2.html
    Oct 2013
    Do you not have the technical abilities to disassemble that axis and see for yourself if a double-nut will fit and allow full range of motion?
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
    Mar 2014
    Turkey
    Quote Originally Posted by atomarc View Post
    Stuart
    Stuart,
    It's not about ability. It's about saving time and effort. But here's your answer:
    To disassemble the table I first need to disassemble the enclosure. To disassemble the enclosure all the individual oil lines must be removed because these lines and the Z axis cables comes trough holes on the enclosure. Once these are removed I need to lift the whole machine and put somewhere because it is impossible to remove the Y axis because the chips tray has a high profile front and rear walls so I can't simply slide the axis and remove.
    You see figuring if I can use a double ball nut on the Y axis is quite a work and will take some time. Instead all this trouble someone with BF20L or a similar machine can easily answer just by writing "Yes" or "No" and that is all I need.
    Next time if you have the answer I need please let me know. Otherwise please don't ask helpless questions.
    Suat
    Suat
    yelims20's Avatar
    Mar 2016
    brazil
    After that, I wouldn't tell you even if I knew... WOW!
  7. #7
    Oct 2013
    Suat,
    I was not trying to be 'snarky' in my response to your question. The pictures I found of a BF20L show no enclosure, so I had no idea following my suggestion would be so difficult for you. If the construction of a BF20L is anything like that of a G0704, then a double ball nut will fit..with minor modifications.
    If you look at my build of a G0704, you'll see pictures of the 'Y' axis casting with ball nuts installed...they should be in the first 15 posts somewhere.
    Stuart
  8. #8
    Mar 2014
    Turkey
    Suat,
    Stuart
    I'll take a look. Thanks. And sorry for my overreacted post.
    Suat
  9. #9
    Jan 2018
    United Kingdom
    My machine is a PM25 clone. The manual that came with it is the Chinese WMD25V.
    It's the older style one with the square base. You can look at that and compare the base sizes to yours.
    I have a double nut 1605 fitted and also was able to extend my travel from 185 to 203mm with some 'tweaks'.
    There is an image of the underside showing it fitted in post#6 here:.
