Like many others I found the Consew CS1000 to be an inexpensive and apparently elegant, variable speed solution. I used it to make my drill press truly variable speed. Every thing was fine and doing well until the controller arc'd, sparked and let the smoke out. The recommendation from Consew was that I buy a new motor and controller, which I did. I now have two motors and two arc'd and sparked controller boards. I am hoping that someone has found a controller to replace the Consew controller.
