I saw it a while a go , a open-source cnc mill that used a granite surface plate as a base .
Got me thinking what if i got a piece of granite countertop and bolt it under the little x2 .
A 12 x 18 inch slab polished can be found reasonably cheap . Think it would help ?
Sent from my SM-G991W using Tapatalk
- New Machine Build- How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
- LinuxCnc "Step Time" "Step Space" "Direction Hold" "Direction Setup" values??
- Problem- X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
- New Machine Build- How crazy is this idea for an X2 "staged" CNC conversion?
Thx, yes thats been taken care with a 0.75 x 4 x 15 inch steel plate
I wasted loads of money on mine. In the end no matter how solid it is, the carriage/table are a big flaw. There's no getting away from table twist whilst milling.
It's now just sat there half in bits.
If you could manage to fit DFU nutted screws in there to solve it and/or rip it apart to fit linear rails it would be solid.
Is it worth it.... No.
Admitting defeat and buying a 1.1kw PM25 sized machine to tinker with instead of wasting more effort was the best decision.
The weakest part of these mills is the connection of the column to the base. If you are not fixing that you are not fixing the problem.
The next worse part is the machining tolerances of the dovetails and slides.
What you are suggesting might improve something, somewhere, no denying that. But it might help maybe 2% of the problem. Is it worth it? only you can answer that.
